2 coolant temp sensors...
Loeryder
In case you didn't know yes there are 2 coolant temp sensors.
1 is for the gauge and 1 is for the ECM...
Coolant temp sensor: Top Left Side of Manifold
Connection C133, circuit #s 410-0.8 YELLOW & 452-0.8 BLACK
YELLOW goes to pin E16 at the ECM connector C311, lowest connector on the ECM as dropping it down.
Coolant temp sensor: LH side of Engine
Connection C153, circuit #35-0.8 GREEN
Goes through bulkhead connector C100 ends up at pin R at connector C200 at the Instrument cluster.
Hope this helps someone...
