1. IAT's.......I just re-routed my lines to where the IC lines goes down the drivers side to the heat exchanger then comes back up the passenger side through the fender well to my heater core then from there to the upper IC. I have gotten almost all air out of system being as the cap is highest point and all, is was pretty easy.
I am running the Shurflow pump mounted in the stock location. I even went as far to pick apart the local auto parts rad hose section to find good molded hoses so I wouldn't need any 90*'s or anything. Even found a killer hose from the exchanger to pump, does a nice little swiggly so i have no concerns of kinking anywhere in my system now.
My IAT's are hovering around 90* or so now and they stay around that with the AC on or not. My truck is on jackstands waiting some TLC so all the temps are just idling. I did sit there and rev the motor until it got to about 130* then waited to see results went right down to 100* but wouldn't go back to 90* even with AC going. The fluid was cold to he touch in the IC. I guess my question is; is this normal temps for this kind of setup?
2. Block Learn Numbers........On my TurboLink there are 2 different BL numbers. The top is INT and the bottom is BLM. Well my top is hovering right at 128, stay there most of the time, even under hard acceleration. The BLM is staying around 150-160 when idling but under hard acceleration is shoots right down to 128-130 and doesn't move.
Could someone explain this to me? I think it means that at idle I am running either rich or lean, I think lean cause 160 is in the red area and not the green, but under acceleration it goes to about where I am supposed to be. Seems I read that 128 is neutral and running as it should.
Anyone using TurboLink pretty regular, if so I would appreciate some tips and things you might have discovered. :lol:
