hey so my ty needs an engine rebuild and i cant afford to do it rite now. i was looking into swapping a 2001 or newer vortec. what would i need to change to make this work in a typhoon?
You really need a custom chip for this to work, and you may need to do it yourself with code $59. It flows a lot more (better cam/heads) and the higher compression require more fuel as well. If the tuning part scares you, I wouldn't do it.
Can you afford this? http://www.sytyperformance.com/inde...facturer_id=0&option=com_virtuemart&Itemid=26
I dont know if you are asking for opinions or not but I would just wait until you have the money and do it the right way. It will save you time and headaches if you just put a motor in once. I did the RPM build at a local race shop with L35 heads roller rockers and a 412 cam all installed for $3200
