20G or PTE-51,52?
Treymen
I'm kicking around the idea of a larger turbo. From what I've read, a 20G is a great turbo. But I've also been told it's power capacity is not enough to get a truck into the low 11's
My build is stock motor. Ultimate chip, RPM A2A, Meth, 3"ATR exhaust, electric fans and electric water pump.
What are the pro's and cons of a 20G and the same question for the PTE's
I'm looking for 11.30's
Re: 20G or PTE-51,52?
Yeah, A 20g is not the right turbo for the times your looking for. You should pick atleast a pte52, I would probably pick a pte6262. I wouldn't go any bigger than that for stock heads/cam.
Treymen
Oops. Forgot to add massaged L35's and slightly larger, more aggressive cam are in the works. As are code59 and 60# injectors
Treymen
cloneman315
I also went in the mid 11s with 52 on a stock motor heads etc,just need to get that 60ft down,great street turbo.
Treymen
Sounds like with my build, the 52 will work well.
I'm also putting the sy on a diet in the next couple weeks. My plan is to lose around 100lbs off the fronted. Then transfer the battery to the underneath spare tire location.
And another 100lb off the nose when the coilover goes in next year.
Hoping for a total weight savings of 250 when its all said and done.
Darin
Buy a normal 14cm 20G to start with, and as your power needs increase, modify the compressor side accordingly. Campbell made some insane numbers with a 61mm comp wheel on a normal 20G.
20G is a direct bolt on, really easy to deal with, same downpipe, lines, everything.
SYO237
SyTy Registry
x2 on similar setup.
PTE52 with open downpipe, 60#s
I dumped my fenderwells (more for ease of working on the damn thing), battery is under the bed, ABS deleted, wiper reso deleted, A2A, ramchargers, EGR deleted, cruise deleted, upgraded steering shaft....
Truck is currently undergoing a full Code59 tune right now, should hopefully be ready to go in December. Goal is 11.7s on stock heads and stock block without alky....heads/motor has NEVER been opened.
cloneman315
Mine was also unopened 60ft will be the key,I also was running a stock ic,but i was running c16
It's just a six
Super Member
Does the 20G spool up quickly?
With the 14 CM it's a bit laggy. Min stall needed IMO is 2600.
I have a 12 CM turbine housing w/a 60-1 compressor wheel & I get by w/the stock 2100 stall stock.
When I switch to the 14 CM housing, I will use a higher stall converter for sure.
