Re: 20G Turbo Info Please
Do you know from personal exp that it will be laggy ? I've heard otherwise from others about just Rolling a 20g w14cfm housing on a stocker. But hey I'll be trying that here when mine 20g shows up on my door step! So I will keep you all posted ,at worst case scenario I doesn't work ! Best case I prove a lot of people wrong and it works out fine! I'll keep you all posted!
From what the others that say there stock Sy/Ty worked great w/a 20g turbo, tell them to post up some videos or time slips.
There will be no best case scenario when it comes to a stock Sy/Ty & bolting in a 20G turbo.
It is going to run so poorly that you will probably want to get rid of it.
But hey, it does not hurt to find out first hand, all you loose is the time it took you to install..
Did you ever time your vehicle with the stock turbo? Just to see how much slower the 20G turbo will be.
I drove my friends stock Syclone that had 80,000 miles on it, It idled fine, engine ran OK, I tell you this is the honest truth, When I floored it, I mean floored it, (we even checked the TB to see if it was open all the way) floored it & the most, I mean most boost it got was 2-3 psi, no matter how long I kept it floored..
Then I had told him to port the turbine housing to port match the exhaust manifold to turbine housing. (There is a huge port mismatch)
Well after that porting, we could muster up to 5-6 PSI @ the absolute most.
So, even when we got to 5-6 PSI with the brakes applied (boost launch) when we would release the brakes, guess what happened,,,,,,,,,,, it launched like a SNAIL. I mean slow, real pathetic.
When is this 20G turbo going to be installed & having you or a friend video taping it so we can archive the results?
I cannot hardly contain myself. This is so exciting.:tup:
