2bar to 3bar senser for chip
Plan9
I got my ultimate chip a while ago but still haven't had the chance to hook it up yet. a friend of mine went to install it for me one time while i was at work, but it didn't work properly. he installed the 3bar senser without the chip and said the ty ran like poo and wouldn't idle right. does the 3bar have to be installed with the chip to work properly? shouldn't the 3bar just work anyway? i bought the 3bar from the dealer,"new."
Loeryder
YES
3 bar sensor only works for 3 bar chip
2 bar sensor only works for 2 bar chip
it all seems so simple now
InvisiBill
The way I understand it, the 2-bar and 3-bar chips use the same voltage range or whatever to represent either 2 or 3 bars of pressure. In other words, your 3-bar sensor at 30psi is sending your 2-bar chip the signal for 15psi. And your 2-bar sensor at 15psi is sending your 3-bar chip the signal for 30psi. I agree that it would be nice to have a 3-bar sensor that sent the same signals for -15 to 15psi as the 2-bar did, so they were interchangeable... For now, the sensor absolutely has to match the chip, or you'll be sending it really messed up boost readings, one way or the other.
