3 bar MAP question
just a 6
R.I.P MyClone
I have a stock Sy so far, but i bought a 3-bar MAP sensor b/c i was going to get the STG chip. So here is my question:
I installed the 3-bar MAP on my truck and it ran like crap, i put my stock 2-bar MAP back and it run fine. Have anyone else had the same problem? I assume that the STG chip is calibrated for a 3-bar MAP, correct me if i'm wrong? The part # on my new MAP is 16040749.
I'm having a bunch of mods in my garage that is going on my truck as soon as i get some time over (new 20G is one of them).
Preciate any info, thanks.
0966Sy
Code what?
yep your right on the calibrated thing.
(yes the 3bar has to be ran with a 3bar chip)
Erik'
InvisiBill
I believe the 3 bar sensor sends the same voltage range to the chip for all three bars as the stock sensor sends for 2 bars. In other words, the 3 bar at 29.4psi is sending the same signal as the 2 bar at 14.7psi. But I'm probably wrong, so someone please correct me...
The stock 2 bar sensor can only sense up to 14.7psi. If you run 20psi on a stock truck, the computer still reads the sensor as 14.7psi, and sends the proper amount of fuel for 14.7psi. I think you can see how this would lead to bad things if you were running much higher boost... The 3 bar sensor can handle up to 29.4psi (another 14.7psi, or 1 bar). The 3 bar chip is programmed to recognize the boost levels up to 29.4psi, and can adjust fuel accordingly (so you'll get 20psi worth of fuel at 20psi, instead of 14.7psi worth).
Ian Turgeon
Cascading Inspiration
Thats pretty much it. Same voltage range as the stock sensor, except that voltage represents a different pressure, so a 2bar chip wont understand a 3bar sensor and vice-versa.
as far as getting the right fuel for 29psi..
Theoretically thats the right idea, exept you have to remember that the stock fuel system is marginal at stock performance. Obviously there would have to be some changes to support 30 psi.
But then again the stock turbo runs out of effeciency around 18psi so you have to think about fueling for a bigger turbo and with that a different air... blah blah
Its almost like trying to figure out what would happen if you went back in time and married your own mom. Props to the chip tuners like BG out there that have a hard enough time trying to make a chip work on one truck, not to mention the majority of trucks.
syntax
a 3bar map will NOT work with a stock chip, i had put my 3bar in and started her up a few mins before i slapped myultimate in, and she could hardly idle, then i put the ultimate in and she was golden
InvisiBill
I'm no expert, but I'd think you'd need a lot more than just a better fuel system to run 30psi... =) Also, what happens if I marry your mom?
I was just trying to say that the stock 2 bar system is maxed at 14.7psi and sees anything over that (whether it's 15.1psi or 30psi) as 14.7psi. And that the 3 bar and Ultimate are designed to be able to read an extra 14.7psi, and can thus control your truck for 18psi or 28psi or whatever properly. But that the 3 bar sensor uses the same voltages as a 2 bar, so it will send "screwy" readings to the stock chip...
In that sense, it'd be nice if the 3 bar just had an extended range to cover the extra 14.7psi. So that it would put out the same reading as a 2 bar up to 14.7psi, but could also read up to 29.4psi if you had a chip that could understand that extra voltage...
JoeLutz
Guess that would make you his daddy.
I hooked up the 2bar sensor to the three bar chip just to drive it home while I was waiting for the 3bar map sensor to come in. Talk about running rich!
