3 bar map question
BMFB
Not to scale
now, i searched through the forum and couldnt find what i was looking for, but can i take a 3 bar map sensor and hook it up to a stock ecm and it work ok, i realize the stock chip prolyl doesnt know how to use the additinal information past 15 psi, but could i still plug it in if say, it was all i had
NorwegianTy
Re: 3 bar map question
Won't work right, without a chip burned for 3-bar. Truck will run like ass, if at all.
x3
The map sensor output is a linear signal in either volt or mA. I think its volt and it is between 0 and 5 volt. A two bar map sensor would in such a case show 0 volts at -15 psi (-1 bar), 2,5 volts at 0, and 5 volts at 15 psi. A 3 bar would be 0 volt at -15psi, 1,67 volt at 0 psi, 3.33volt at 15 psi and 5 volt at 30 psi aka 2 bar.
If you dont reprog the chip the ecm will give out complete wrong amounts of fuel.
BoostedSUV
It will run I have tried it, but as soon as you start getting into boost the truck will start breaking up and popping.
