3 Bar MAP Sensor connector
A local Ty owner asked me where to buy one from. (It's been a long time since I bought a 3 bar MAP.) The GM TTA 3 bar map sensor seems to need a new connector. Are there any aftermarket 3 bar map sensors that will plug into stock MAP connector?
TYTILIDIE
METH HEAD
Re: 3 Bar MAP Sensor connector
The two I bought from GM came with the connector. Other wise, I have had good luck with many connectors at NAPA. First time I did a 3 bar MAP, I actually used an exacto knife to make the stock connector work.
13Pelle
Maybe here.....not sure on the connector though. My 3bar went straight in with no issues. I need to get another one also, hopefully the new one fits just the same.
MRKING
New Parts for Old Trucks
Ive never heard of this and mine too plugged directly in the oem connector . Any vendor here that carries 3bars should be a direct fit .
BoostedSUV
My 3 bar plugged directly into my 2 bar connector as well. I know for a fact that the 1 bar connector is different but with an exacto knife as mentioned above can be made to work easily.
13Pelle
All my 2bars and 3 bar are identical looking. I only knew what was what from the numbers on them. I had always assumed the two were the same connection wise.
SY-1193
I purchased my 3-Bar from GMPartsdirect.com and I also purchased the new connector told that I needed it...I never used the connector. The 3-Bar plugged right into my Syclone's harness no problems. You can get one from MSD or search it is available from many other sources.
