3 bar map sensor
sy538
Re: 3 bar map sensor
To use a 3 bar map sensor you have to use a chip programmed for it. The 3 bar map sensor you have to use is for the 1989 Turbo Trans Am. It reads 1 bar of vacuum and 2 bar pressure. I don’t know what the sensor in the link is for but it looks like it only reads boost and not vacuum. How much you gain by running a 3 bar map and chip depends on how much boost you can run without knock retard. Fill it up with race gas and turn the boost up to 20-22 lbs and you should gain alot.
JAY
I thought by adding a 3 bar the computer could adjust over 14 psi?
SeattleSy#1255
Category 5 Conservative
if you are going 3 bar go with a GM.
your ATR chip is a 2 bar chip...if you go 3 bar, get a 3 bar chip
jwaller
Evil Genius/SyTy Guru
the programming must be changed to take into account the different map sensor. and thus give you the ability to tune correctly for over 14.7psi of boost.
you can always run 30psi on a 2 bar but the ecm just see's 14.7
JAY
Thanks I understand now. I have to save up now for the Ultimate.
