George Blake
DONATING MEMBER
This was over on turbo buick. It's old but thought I'd share it. Might save someone some trouble if buying a used sensor. Sorry if it's a repost.
3 Bar MAP sensor wiring faq![]()
Those purchasing new 3 bar map sensors from AC Delco part numbers 213-1562 or GM 12223861 the sensor is wired internally different than the original TTA 3 bar.
The correction involves swapping the power and ground terminals to it. Whereas old sensor wiring is
A= 5v
B=signal
C=ground
New wiring for 12223861 or 213-1562
A=ground
B=signal
C= 5v
Hope this saves someone from buying the GM harness that reverses the wires for 30 bucks![]()
This only applies to 3 bar map sensor users![]()
__________________
89 TTA Stock appearing![]()
10.550 at 132.22 1.539 60ft 3850 race weight w/driver
Always on 93 octane
www.alkycontrol.com
727-570-9999
