Re: 3 bar map?
Pretty much all of the aftermarket chips currently offered *require* a 3 bar MAP sensor.
The sensor by itself won't do anything, other than make your truck run like crap. The software the ECM is running has to be changed to deal with a 3 bar sensor. (Not just the calibaration; the actual machine code)
The stock sensor can only 'read' up to 14-18 psi, depending on your base altitude. 3 Bar sensor has a range of near 30.
