3 bar map
bloque
Hi, can i use the 3bar map sensor without the chip,because my ty has stock turbo.how can i get more boost with the stock wastegate,turning the rod back or forth,i will apreciate your knollegement.
Tooky
Serious about performance
No, you can't raise boost without adding a chip. You'll simply hit the fuel cut (like a rev-limiter) and cause Code 31 check engine lights.
sytyfreak
Re: 3 bar map
Like the guys said the answer is no. I'm a newbie, but I'm from Puerto Rico too :) perhaps we could arrange a meeting???
I sent you a private message!!
