3 bar question
turbosonoma
Ok i know im an idiot, but I NEED somebody to explain all this stuff to me. I understand the 3 bar only works to 14.7 psi etc... So obviously if i want to run say 18lbs i need a three bar for proper fuelling etc... But what else do i need to get everything all tip top and working great? So i go get a three bar map sensor and one of them fancy ultimates that i was planning on getting anyways and im set? What else do i need? How much is a 3 bar? My motor is basically stock except for dequick afpr, and a walbro 255, so that should have the fueling end of things taken care of right?
Thanks for any help
Brad
Saudi Sy
That takes care of all of the basic stuff that will get you ready with the Ultimate. I believe a 3 bar MAP sensor(part #16040749) from http://www.gmpartsdirect.com cost me $55.62 after shipping and a handling charge. List price is $93.49. I would suggest the ATR exhaust and a Kenne Bell intake. Have you done a tune up: Cap, rotor, plugs, plug wires, and a fuel filter? I hope this helps.
Bob Bertermann
Saudi Sy #2734
SPiN
Just to restate...the 2-bar only works to 14.7. You will need a 3 bar to go beyond that.
jwaller
Evil Genius/SyTy Guru
yep thats it and do the tune up that saudi reccommended. set FP to 50 vac line off to being tuning.
