3 Gauge Pillar (Engine Temp Hookup) question...
Syclone#1992
SyTy.net Moderator
Just installed my 3 gauge pillar pod, and I am trying to find the best place to hookup in the water temp fitting for the guage. I was going to put it where the stock one is, but I still want the one to work on the dash. I can add an extention to the stock one, and "t" off it, but I don't want to have a huge ass fitting in the middle of the engine bay...
So those of you that have an aftermarket water temp guage, where did you hookup? Got pics?
Thanks
ghettosled
SYTY SUPERSTORE
Re: 3 Gauge Pillar (Engine Temp Hookup) question...
Assuming it is electric you will need to adapt your 1/8" sender to whatever size hole you choose.
-you can always try the PS cylinder head, in the same spot as the ecm coolant temp sensor on the DS.
-Possibly the front of the lower intake (best if not using h20 cooled turbo)
-Off the water pump.. some have a fitting?
-DS 1/4" npt plug on the lower portion of the block (oil lines may interfere.. not sure)
-fitting from intake to heater core.. insert fitting with gauge port.
just some suggestions
nallj92
i have a aftermarket temp and im planning on putting it in the passenger side head like this picture here where the plug is currently, look next to the red plug wire and you'l see the brass plug, it'll go right there
Syclone#1992
SyTy.net Moderator
Well I ended up doing something a little different. I tapped into the heater hose on the IC lines, and I am going to be able to read the temp of the IC. I will have to see if it works or not, but I thought it would be cool to be able to see how much heat soak is going on in the IC.
