3 intercoolers?
HotRudyRod
Ok, i have the stock IC, wanna put an auxiliary cooler besides the NOS cobra intercooler bar, do you guys think there's a big gain in intercoolin or just not after a point? I think i need cold better then pressure. i got the pro alki kit and the Ultimate and a lil bigger turbo, no biggie but big hopes. I think my truck is one of the ones that runs good on cold air.
Re: 3 intercoolers?
If you have the l/a ic it wont do much. The alki kit is you best bet. There are gains to be had, but there are also peps that have went 10's on the stock ic.
blk00z28
Forced to by choice
Re: 3 intercoolers?
Just make sure your IC pump is always on or you'll see temp's like you've never seen before.
HotRudyRod
Re: 3 intercoolers?
Thanks, i already did! I had the 20 G, the Ultimate and the rest to get the chip working just installed when the IC pump jammed on me at the race track with over 20 lbs at the mid timing setting! I cant thank enough those guys who recommended me Julio's meth progresive system but still thanks Nightdriver, who knows how much money those 300 or some bucks i spent saved me on the long run ( noticed the gas milage went up too ).
Ps: The night before at 3 am with very cold weather the truck was running amazing with the same chip settings.
Jimmy
Banned
Re: 3 intercoolers?
IMO the ATR aux kicks ass.I didn't think it was shit,but when I pulled mine off the IC went from "Lay your hand on it any time" to "DO NOT TOUCH"
I'm putting it back on,and I have alky injection.
HotRudyRod
Re: 3 intercoolers?
That's exactly what i was thinkin Jimmy, plus a NOS spray bar on either one of them. There was an ATR auxiliary IC for auction on e bay a few days ago. Didnt get it tho.
Jimmy
Banned
Re: 3 intercoolers?
I could not believe the difference.I took it off cause I was thinking it was blocking airflow through my radiator,but the coolant temps stayed the same whilst my IC temps got stupid hot easy.
With the aux IC IAT's stayed 20 above ambient,now they get stupid hot quick.
HotRudyRod
Re: 3 intercoolers?
I'll wait and see how the stoker, a bigger IC pump and the spray bar work out and then if i still see hi temps after a run or some trashing then i'll try gettin me one too, thanks man.
nightdiver
Re: 3 intercoolers?
Ok , its time to talk with numbers.
23 psi with meth and i logged 73*F (two meth injectors)
21 psi W/O meth and i logged 144*F with my huge A2A
Both loggs were on a 90-100*F day
Anyone else with readings ?
