3000 rpms engien stall -,-
Matarex
Ty 93#1612
well just got some new parts for the ty a phill long chip, walbro fp and 3 bar map (the combo need to run the chip) now i have looking all over the place for a posible anwser for this problem...
just started the car up(no prob.) and start to drove i down the street , stopped and did a small lauch drove fine untill around 3000 rpm´s wot it was like it just coulden handle the fule or somthing there were no boost at all on the guage! the was enginen stalling all most sounding like it was drowning and there were abit of knock (had datamaster conceted it read somthing like 2000knock, and there were no boost in the program either(it was changed from oem to a 2-3 bar in the program))! now whent back to the garage and checked the varcum line to the map for leaks and rips, #nothing,,,changed the map back to the oem 2 bar, (keep in minde the chip requres a 3 bar map) i just reved it up to 4000 rpms lots of boost on the guage(and in datamaster, i think i was like 10-12psi boost) it sounde nomal ...my thought is its a buggy map!? but im a noob when it comes to the art of tuning ^^ so im learning as i go along ,,,,,its there a way there i can messure/test the 3 bar map? or am i looking in the wrong place, any idears
oh a while back i had some rpm gauge needle bounce!? "that was wirde" the engien was just about 2500-3000rpms and climbing and it just a lot of enigne power! it came back when i held of the pedle don´t know if it has any to thing to do whit this
there might some speling bugg¨s hope you can read it :roll:
Luke
Fish sticks SUCK !!!
Re: 3000 rpms engien stall -,-
if the display is on "0" it will do that, its the emmissions setting.
Matarex
Ty 93#1612
damn, forgot to mention this tryed all the settings -.- hmmmn i need to ask this q to shout i turn of the engien when changing the setting on the chip?
Luke
no it doesnt matter. How fresh is you tune up?
Matarex
Ty 93#1612
i gues it´s prety old becours i have never changede the wires or the rotor but the plugs are like 1 year old or 10k miles (only had the car for 1 year now) ill start to check that out then
SBNova
If you have knock retard it will pull boost. I dont know anything about Phils chips, but thats how stock chips are programmed. If you actually heard knock, then you had ALOT of knock. The knock sensor starts pulling timing and boost when you cant even hear it. Thats my guess as to why your truck fell on its face. Try better gas (were you running super?), fresh plugs like NGK UR5's (not a hot plug at all), and make sure your IC pump is working if you still have air to water.
Matarex
Ty 93#1612
think i found the main problem it was a faulty dumpvalve(blowoff valve) #brand new btw. but removing it got rid of the stall/cutout
still have a some knock i high stress rpms // ill replace the plugs and wires this weekend to see if it helps on the knock, the sucky bit is im running the best fuel advalible at this time :/
ether way thx guys :tup:
