machine shop said:We have resolved our cutter problem, and I decided it would be wise to send
a couple finished shafts to heat treat before we go much further, to assure
distortion in heat treat doesn't give us problems.
So, (2) shafts went for heat treat Wednesday, should be back Monday. My only
concern is the fit of the internal spline, so we shall see how they look
Monday. The fix would be to adjust how deeply we cut the spline, no problem,
but we want to make sure we make good parts!!
machine shop said:We should finish all the spline cutting today. Final heat treat about 3-4
days. Then finish grind about 4-5 more days, so hopefully by 5/27 or 28
we'll be all done.
So they are ready then?
Jeremy has boxes, and addresses so they should go out monday aside from a few being picked up at nats.
That would be picked up at homecoming 2010 not nats 2011 in Denver.:tup:
I have them at my place will work on boxing them up nice and tight this weekend and start shipping'em next week.
Please note that they all will not go out monday. I am shipping them out as they were ordered and payed for. #1 first, then #2, etc. Should have them all shipped by end of next week. Unless Jeff gets of his ass and comes up and helps with labels and boxing them up.
Also Jeff needs to draw up a diagram with instructions on shortening 4l80e stock 4wd output shaft by 3/8"-1/2".![]()
Do you not need the adapter when shortening output shaft? Or Do you need to do both?
Still have to have a an adapter to bolt a syty transfercase to a 4l80e. The stock 80e 4wd output shaft needs to be shorten to allow the transfer case to engage far enough to properly bolt to adapter.
Thats what I figured just wanted to be for sure . Thanks . Btw you guys plan on making adapter plates in the future![]()
