Re: 383 Syclone
NOJIMMY said:
...not that this answers your 383 question directly, but in the latest Hot Rod Mag
a gentleman asked a similar question about "costs for a twin turbo 327 build".
Their reply was this:
"Here's the typical ballpark figure...you're looking at nearly a $25,000 outlay!"
Turbos......................$2,000
Wastegates..................$1,000
Fuel Management.............$2,500
Intake & injectors..........$1,000
Throttle Body.................$400
Hi Capacity fuel pump.........$500
Custom Headers..............$5,000
Intercooler and piping......$2,500
Engine rotating assbly......$2,000
Cylinder Heads..............$1,500
Block Machining-balancing...$1,000
Hydraulic roller cam-liftes...$800
Roller Rocker Arms............$300
Misc engine parts.............$500
ECU Distributor, coil, wires..$500
Engine assembly labor.......$2,000
Tuning via chassis or dyno..$1,000
Total $24,500
Finally, there are integrated aftermarket all in one kits,
but most of them are designed for 350 or larger small blocks.
In theory, by varying turbo compressor and turbine wheel
parts they could be adjusted for the smaller 327s. Two leading
twin turbo kit vendors are Gale Banks and Nelson Racing.
-Larry
Some of those estimates a bit high... while $5,000 for custom headers is possible, I would hope you could get it done cheaper.
But I think your better option is to fix the six. There's something cool about stomping mustangs with six cyl.
If you wanna do a 383, get a regular s-10 or sonoma.
Here's a sampling of what my build cost:
98' Sonoma X-cab Stepside..................$5,000
60k mile LT1 w/T56................................$1,500
Forged rotating assembly.....................$1,500
Ported LT4 Heads...................................$1,200
Machine Work.........................................$1,200
Spec Stg II clutch......................................$300
Coated Shortie Headers.........................$300
58 mm TB.................................................$300
1.6 rr's......................................................$300
Ported LT4 intake....................................$250
Comp Cam...............................................$250
30# Injectors...........................................$200
There's more to it... but I don't want to think that hard. Nor do I want to add it all up :roll:
No power adder, yet. But I still haven't gotten a clean all motor pass in.
