3bar questions?
badasiwnab
When I set the chip on T1-15,16,17,18 and valet my truck dies after idling for 2 or 3 minutes and will not crank while on these settings. I have to set it on T1-20,22 or T2-17 to crank it. I would greatly appreciate any help that I could get. The fuel filter has about 3000 miles on it and I'm going to change it just in case.
badasiwnab
It's the 50lb setup with stock motor and a bigger turbo. I also found out that on T2-18,19 and 20 it won't idle, but when I do get it cranked on these three settings and I give it gas at a idle it stumbles and sputters.
I don't know if this helps but it used to crank on the first couple of T1 settings but it would act like it was leaning out by sputtering real bad until the truck was moving.
I just purchased TurboLink 4.0 so I could tell you anything you needed off of that.
smeagol
You probably have V2, which has a problem I resolved in V3.
http://www.chitownsyty.com/bg/chipstuff/50v2.htm
This has the layout. The problem is that the changes made for the WOT fueling, they affected the running condition at ALL times.
So basically, if you go to fueling level 5-6, it should run fine. This is why you are seeing problems in certain programs.
Check what program you have, if it has v2 on it, let me know and we'll get you the latest.
