4.3L Auto w/ turbo in a B4U 96 SS S10
sypwrdss
Starting a thread here for my Conversion I have been working on for over a year now. Lots of pics to come...
Here are the STOCK SPECS:
1997 Chevrolet S-10 SS (2-Wheel Drive)
2WD S-10 Pickup
Engine:
Vortec 4300 V6 (L35) (4.3L)
180 hp at 4400 rpm; 245 lb-ft torque at 2800 rpm
Transmission 4-Speed Electronic Automatic
Eagle GA P235/55R-16 tires
16" 5-spoke cast-aluminum wheels
Suspension:
ZQ8 Sport Suspension Package (including Bilstein shocks and big stabilizing bars)
2'' lowering
Monochromatic body, grille, and bumpers.
Onyx Black, Apple Red, or Summit White.
[/IMG]
Daily Driver from 08 till late 09.
Interior shot as it was while it was a Daily Driver
sypwrdss
Re: 4.3L Auto w/ turbo in a B4U 96 SS S10
Bought it from a guy in Arizona late 2008.
No winters EVER = NO RUST anywhere.
Wing and Tonneau Cover are gone.
sypwrdss
Engine before I tore it down. Nothing wrong with this truck at all, just wanted something more interesting to drive.
sypwrdss
[/IMG]
Here it is tore down to the BARE frame. Recoating it with Master Series Chassis Saver, much better than POR15.
sypwrdss
Frame done top to bottom, now I gotta do the inside with this stuff I bought from eastwood.com. It has a long sprayer to get deep inside the frame.
sypwrdss
Going back together along with rear end rebuild and disc brake conversion.
sypwrdss
Installing the front suspension, all new bushings, bearing, seals, ect...No wearable items reused.
sypwrdss
Since the rebuild I have decided to go with these after the truck completed.
sypwrdss
Mercruiser intake swap, Now I can change out injectors to suit my needs for fueling. Also deletes the EGR with this swap.
96 up OBD2 factory dist. I love how they done the plug wire routing on these. V-6 and V-8 from 96 Vortec all had these if I remember correct.
sypwrdss
Going ATW on this one, this build shall be close to what a syclone would have been if GM ever made them for the 94 up. Minus the AWD, sure wished it was.
sypwrdss
What kind of distributor is that? Marine specific? Cool project!
Acually that is the 96 up OBD2 factory dist. I love how they done the plug wire routing on these. V-6 and V-8 from 96 Vortec all had these if I remember correct.
