4.3L Camshaft List - Spreadsheet
sytyguy
Moderated User
I found an old spreadsheet I had started years ago with all of the available 4.3L camshafts (esp. those for the SyTy). I completed most of it today and figured I'd put it up for you guys. Basic spreadsheet format, but it makes it easy to compare cams and make graphs if need be. I plan to integrate this (as well as many other comparisons like this) into the Tucker AP website in the future, but this should suffice for now.
Right click image and save target as.
Hood
SeattleSy#1255
Category 5 Conservative
Re: 4.3L Camshaft List - Spreadsheet
hey mike, is there a way to specify which ones are blower cams and not? Or does it really matter...reason i ask is i was under the impression that cams such as the comp. 412, 415, and 422 are actually designed for N/A applications. Then again what do I know?
blk00z28
Forced to by choice
sytyguy said:
Works for me......you're saving the target, not the image, right?
direct link - here
Hood
Yeah, wtf.. Maybe its my firewall blocking it for some reason. Still shouldnt block it by save asing though.
(got it now.)
steve-o
I have a q for Hood or anyone else who might know.
Do camshaft manufacturers typically advertise the Intake/ Exhaust lift specs with the assumption a 1.5:1 rocker is installed? Or is the lift advertised as Net lift, i.e, the actual height of the cam lobe from it's base circle?
For instance, the Comp 412 advertises a lift of .500". If that is the height of the actual cam lobe, then a 1.5:1 rocker arm will yield .750" gross lift at the valve!! That's Nascar teritory so I doubt it. But, if the specs are advertised as gross lift with the assumption a 1.5:1 rocker is being used, one could decide to slap on some 1.6's, etc. and they would no longer be making the advertised lift.
Furthermore, 1.5:1 rockers might be a typical rocker ratio for GM applications, what about Ford, Dodge, etc. and how are their pushrod engine cam specs affected? What is the common factor when it comes to working out and understanding these lift numbers?
BTW our stock cams are dinky!
sytyguy
Moderated User
The standard measurement level for duration and lift is .050" lifter rise. So, ignore the advertised values for cams as advertised values are taken at no specific point and can vary greatly. Keep in mind, though, that lobe lift is different from valve lift, and as such, most manufacturers rate valve lift with a 1.5 rocker ratio. Confused? Here's some math to help clarify:
Example - camshaft A
cam A lobe lift = .320"
rocker ratio = 1.50:1
cam A valve lift = lobe lift x rocker ratio (.320 x 1.5)
total valve lift = .480"
Change the rocker to 1.6 and you get a total valve lift of .512". So, how do you find the increased value without knowing the lobe lift? Divide the .050" valve lift by 1.5 to get the lobe lift. Multiply new value by new rocker ratio for new valve lift. So........
Example - Comp 412 camshaft
.050" valve lift = .500
.500 / 1.5 = .333
.333 x 1.6 = .534
So, a Comp 412 cam with 1.6 rockers would have .534 valve lift (up from .500). Pretty nice increase. Keep in mind that this also assumes correct length pushrods and valves. Anything in between the cam lobe and the valve can affect overall lift (including lifter, rocker, valve stem, rocker height, geometry, etc...). Also keep this in mind when choosing valve springs as you want to avoid coil bind around max lift.
HTHs
Hood
steve-o
sytyguy said:
... most manufacturers rate valve lift with a 1.5 rocker ratio.
Ahh, that's what I was wondering. Thanks for the info!! :D
BTW - I like the spreadsheet. :tup:
