1991 - 1992 GMC trucks with the RPO ZR9 Syclone Appearance Package, and 1992 - 1993 GMC trucks with the RPO Z79 Typhoon Appearance Package were equipped with the 1987 - 1993 LB4 4.3L engine block, crank, rods and cylinder heads. However, the LB4 engine blocks used in the Syclones and Typhoons were upgraded with 2-bolt nodular iron main caps.
The question was "difference in blocks" and I covered it completely. What did I miss?
The Pistons.
He said block, not short block, the pistons would only be included in a short or long block
If you will search the Vault and read this, you can find just about every answer you are looking for.
the holy grail of 4.3 info!!
Yes HE DID, That being the case WHY did MoJo list the following in His reply? NOOB....
:rotf::rotf::rotf::rotf::rotf:
