with cement to the block but i would agree with king datonation is the one facter if you datonate 100hp is to muchsafe it would be 500 hp to the wheels . 2 bolt.for 4 bolt is 650 hp .
.a good tune is very important.with cement to the block. but i would agree with king datonation is the one facter you have to considere.:2cents: if you datonate 100hp is to much
i've seen 3 broken cranks,and they were all on non tuned trucks. i think the safety feature of something going wrong and keeping it all together is a big plus. instead of breaking the crank and the rest that goes with it.
On the broken cranks you have seen where do the cranks tend to break? Is it the offset rod journal?
If you already have the motor torn apart, why not just 4bolt it? At least you know it's gonna hold with a proper tune.
I found a thread on here that warns about drilling into the blocks water jackets during the 4 bolt main conversion process:
http://www.syty.net/forums/showthread.php?t=28345&highlight=bolt+main+bearing+water
You dont have to do splayed 4 bolt mains. Mine are not.
people went low 11's on stock blocksWhat kind of power do you think my stock rods will hold (of course with out detonation)
I was considering getting ARP rods bolts installed into the factory rods, should I step up to Eagles?
Any info about the scat Crank? I think its a cheap cast crank so the OE stuff is probably better. Any opinions?
