TurboManiacal
Hey All,
Got an update for ya...also would like to get a read on where I'm at with the truck.
Got to get into the Sy some more this past Sunday...unfortunately won't beable to get near it again for some time. I'm going to Paris / London this weekend. I'll post pics afterwards.
Here's the deal. Truck has run like shit ever since the new motor...but I think I'm getting closer...while I haven't made it run any better I've gotten it to the point that I can almost taste it running good.
This past weekend I dug into the AFPR and got the PSI down to ~35psi. Not sure exactly where it's at as I didn't set it properly but I sure as hell know it was way too high (~65) before I started. I'm going back in there again later. The sever popping in the Cat has died down and the exhaust isn't any where near the same smell as it was before.
Playing with the wires (swapped #1 & #2...90' plug vs. straight plug) and the distributor I confirmed I had everything right and started it back up. (Confirmed TDC with timing mark by rotating crank) It was still off and I couldn't get it anywhere near 0' timing at idle (Tan wire disconnected). It was sitting @ 40' timing at idle.
It's not throwing any more codes and I'm feeling better about it. Willing to do the plugs and wires again...no problem...just need confirmation about the timing and get that straight.
I'm willing to bet Distributor is in wrong. I'm willing to work on this next...but want to hear some thoughts from the AMERICANS. Distributor is at about 45' angle on the flat side to the firewall...big side pointing to Driverside fender. Plug wires are on right.
I'd also like to hear thoughts on whether or not I'm using the right timing mark. There's two on the harmonic balancer. Thoughts?
