Houseofperformance
switchhappy!!!
i´m still running the base program george blake provided on my tci controller and would like to adjust the shift points. engine has a 412 cam, vortecs and 50# injectors and a pte 44, stall is 2800 - at wich rpm should i set the shift points and are there any other changes i should perform when adjusting them (line pressure, lock up settings......) ?
thanks
thanks
