Sy Guy 0024 said:
Can anyone give a part number or manufacturer for the hardened pushrods Patrick mentioned? I also have 412, stock 1.5s, vortecs, ARP screw-in studs, but am looking for a set of pushrods that people have had good luck with. Any suggestions?
Corbin
It's kinda hard to just give out part numbers for pushrods, because you have to check the length very carefully, especially if the engine has been rebuilt. For general use, look for 5/16" diameter, one-piece pushrods.
Both Comp and Crane sell good hardened pushrods (I'm sure there are other companies, too). Both companies can do custom lengths (important tip: if you get custom pushrods, buy 2 extra so you have spares -- otherwise you'll have to wait weeks to get replacements). Crane seems to have more sizes on the shelf. However, Comp's web site (
http://www.compcams.com ) seems to have a better description of how to measure pushrod length.
Also, if you are going to use guide plates, either put adjustable guide plates on the center cylinders, or be prepared to cut and weld the plates to fit. For some reason, GM decided to use a slightly different location for one stud boss (think it's the intake valve, but can't remember for sure) on the center cylinder of the V-6 heads. Because of this, the tip of the affected rocker won't be centered on the valve without adjusting or modifying the guide plate.
