tbauer03
TRBOBOX
(Sorry, I am posting this on multiple internet outlets to try and generate some ideas because the Hot Rod Power Tour will be in town tomorrow and it would be nice to drive this over there if there is an easy fix.)
I had my 4L60E running well on a PCS stand-alone controller before, but after rebuilding my engine and consolidating all electronic control to the Holley Dominator it isn't recognizing the transmission.
The transmission is connected using the pre-terminated Holley 4L60E/4L80E harness and it feels like it's in some sort of limp mode staying in only 2nd or 3rd gear. I haven't done any real testing other than putting around my neighborhood at low speeds. And double checking the wiring. Under a little throttle it accelerates predictably, but won't upshift or downshift. The RPMs directly relate to TPS. I did try applying more throttle like 70% to see what would happen and the turbo spools extremely fast, but it barely accelerates like I'm just flashing the torque converter. (It's a 2800 stall, but it feels vastly different than before, actually before it was 3000 but it is the same 9/11 converter that I had John Waller re-stall to make it tighter.)
Anyway, in regards to Holley I do not get MPH displayed on the Holley V4 EFI software in my laptop or my Digital Dash. I also cannot see which gear I'm currently in, when I manually shift from park to reverse to drive etc., or when driving down the street. As far as I know I have it electronically connected properly. Red wire to switched power, black to ground, gray to brake pedal, main connector to the main connector, VSS is on the transfer case, and I had to use an extension to plug it in as the harness was too short. And the 4L60E doesn't use the 2nd sensor that the 4L80E uses. I don't know if my Global File is correctly setup. I basically just answered the generic transmission questions and assumed that would have got me going. Screenshots are posted below. I would be more than happy to email anyone the Global File if it would help, or take as many suggestions on what to try to get this truck back on the road. Thank you, Ted
Here are screenshots of my settings:
