Houseofperformance
switchhappy!!!
have the 4l80e installed, wired up correctly with george blakes modified harness and the tci wp and would need some suggestions at this point:
first:
the tranny works, shifts, downshifts and has od - but i have no lockup - when performing the tcc switch test at the connector i get infinite ressistance what leads me to the idea, that it might be a lose connection inside the trany BUT: i already lost the lockup with the 700r4 and couldn´t even get it to lock with the override switch - where could i check for a problem that dissables lockup in both applications - i´m lost?
second: i cant datalog and can´t connect to the tci wp - when hooking up the laptop and trying to connect i get a "no pcm dedected" message - but the pcm is working, otherwise the trany wouldn´t shift - correct?
any suggestions?
third and worst:
i can´t boostlaunch - when powerbraking the sy, the engine revs up to about 3000 (2600stall) but when letting off the brake, the truck creeps forward for a second or two before taking of - no boost launch effect.
help me out!
first:
any suggestions?
third and worst:
help me out!
