Re: 4l80e -vs- 700r4 weight difference
No problem.....there's a bit more to it as well. Involving how the gearing loads the motor, and the ability to change the shift points to suit the powerband of your particular motor. Also the internal workings are a a bit different in how things stop/start to change gears, and the 80E's design in that area is superior as well.
The biggest thing I've noticed riding in Jeremy's (six-is-enough) truck is the lack of a brutal 1-2 shift that the 700's have. Since the 80E can modulate line pressure electronically, when at part throttle the shifts are crisp, but they don't bang into the next gear like the 700's do. However once into full throttle the line pressure comes up, and you get a good hard shift......Makes driving it around significantly more enjoyable IMO.
There is a review around here somewhere from the last week, where a guy went through the whole change process, and has nothing but good things to say about it.....lemme try to find that for you.
*edit* Found it.....
Click Here for a 4L80E review
Now back to your regularly scheduled tranny weight thread.....Sorry for the hijack Jeff
