50# Bin for startup
Quickstop [UK]
Combating adversyty.
Hey all,
I registered on code59.org and downloaded the .xdf and adf files as well as the autotune spreadsheet. I searched through the available bins but couldn't find anything that I thought suitable.
Could someone please send me bin that might match my setup? My address is mf_edwards@yahoo.com
50lb inj, GT35R, 415 cam, vortec heads, W2A, WB02 (LM 1 Innovate).
I have installed my Prominator setup and need to flash the files into the comp now.
Lots of reading to do :)
Thanks in advance.
Mark
bezerk
Re: 50# Bin for startup
Hey all,
Thanks in advance.
Mark
www.powertuneplus.com has som elisted code 58 but you will get it running with that
skwayb
NWSTP
Mark,
I would Start with Digs 60# bin.
http://www.code59.org/index.php?option=com_docman&task=doc_download&gid=5&Itemid=35
Set the bin to the correct wbo2 you have, then start it. Watch what your AFR is at IDLE and then start increaseing the Values in the F28 (Base Pulse Constant -vs- Desired EGR) table to add more fuel across the board until you get it to idle at 14.7 for a starting point.
I would read this post before hand to help you get started.
http://www.code59.org/index.php?option=com_fireboard&Itemid=38&func=view&id=4679&catid=12
