Well I have the same stumbling problem that the other trucks are having. Stalling, stumbling, hard start,high idle,low idleand just not running right.At first I thought it was the fuel filter or pump. So I droped the tank and washed it out. Put a new 255 walbro pump, filter,screen, and same problem. After it would stumble, lean out, and die. I looked at my fuel preasure and it was not loosing preasure. I figured that I didn't have a fuel problem. I checked my vacume and retorqued my intake manifold bolts. That was ok. Then I remembered that when I first installed the ultimate 50# chip I crimped the ribbin and had simular problems. I played around with the ribbon and got it to run ok, 400 mile later simular problem. I'm thinking of sending the chip to Brian for repairs and putting my old kenny Bell 40# chip in till I get the 50# ultimate chip back. Do you think it would run ok? Thanks Bryan.
Mods are: stage 2 heads, cam,(Mccoy) atr te 61.63 turbo,atr headers,atr full exh.,aem wide band o2,kb boost-a-pump,kb boost-a-spark,walbro 255,ext.
P.S. I broke my laptop, so I can't give you any better # from the diacom plus.
