50# injectors
BigAl...
Are there any cars that come with 50# injectors stock that we could use or is buying them from an after market source our only option?
TIA
BigAl...
SY756
I dont believe any car or truck comes from the factory with 50#ers. Can't think of one that makes enough power to need em. Maybe some exotic but you probably could get six of our aftermarket for just one of those. I don't think that even the new Z06 has any bigger than 30#ers. I haven't really read up on that lately but I know that earlier year corvettes and stangs were only using around 20# injectors. Someone might be able to be more specific on the numbers. Better off just going with aftermarket ones, you will know they will fit and work good.
smeagol
Well I know Supras come with some large injectors, and I'm sure you can find some others, but I don't know of a single OEM production vehicle that uses the high impedance 50# injectors that we have been using. Get 'em from PTE, or Racetronix etc. You have to realize that just because an injector flows 50lb/hr, it won't work with the calibration designed for a *DELPHI* 50lb/hr injector. Each injector out there is different, just because it flows XX lb/hr, it doesn't say anything about its idle/lower pw characteristics.
