I just finished installing the 50# injectors, 3-bar, and Ultimate and it's about 1000% better than when I was using the Pitbull. I am including a link to the datamaster runs for you guys to check out and comment on if you want.
The 50# injectors were easy to install. The intake doesn't need to come off because the fuel rails move enough to unsnap and snap the injectors in and out. The intercooler and AFPR were the only things removed. Just a little info for anybody wondering.
I had forgotten that I needed an aftermarket boost controller with the 50# calibrations so I went to the hardware store and ghetto-rigged a controller for less than $3.00. It is a T fitting with a needle valve to release some pressure and works ok I think. Check out the datamaster file and tell me if this might be why the boost control is crap or if the stock wastegate is just ass. The control wasn't this bad with the Pitbull; it was fairly steady, but the computer was controlling it before. I'm getting boost spikes and whatnot and I'm set for about 16 psi right now. I should have the Ultimate set up for 18, but with the spikes I'm seeing now, I'm not going to turn the boost up yet.
The file has a few runs appended to each other, most of which are T1F6. My mV look good and the KR goes up with the boost, so it isn't false. The last run I did calculates as 14.008 quarter mile with a 2.068 sixty foot. I didn't pump the brakes, so I was creeping at the start of the run. I don't know what real quarter mile times this calculates as, but if the calc is put one Rec# forward, it goes to mid-13s.
Is my IAC way off again? Are my IATs high? Is my boost controller too ghetto or does the stock wastegate just suck ass? I think SeattleSys runs looked similar to mine here with the control issues and so did Xaviers (black Ty on 20s). *shrug*
http://www.wsu.edu/~odiwik/ultimate_boost_cont.uni
