IGottaSy
How would this build perform leaving that 9.08:1 compression and using stock induction components? If I start with 300hp, 15psi later I'd hit about 600hp. Right? I suppose 60# injectors would be border line to tune for 500hp at the flywheel with this build. Race fuel or alcohol injections would be a must as well. Could a TT chip+injectors handle it? what can I expect to end up with as far as compression goes when hitting 15psi? Is it .5 point for every lb of boost? Looks like a stout build to take some good pounding.
http://www.hotrod.com/techarticles/engine/113_0208_chevy_43l_262ci_v6_engine_build/
