749.ecu File Needed...
92GTA
I'm doing a 749 ecm swap into my SC'd 92 Trans Am and I managed to get a copy of the bbzb1580 bin file but I need the 749.ecu file badly to be able to edit it. I use GM ECM Edit for bin editing.
Does ANYBODY have a 749.ecu file PLEASE???
Thanks!
Alex
leroy
There's one at diy-efi's ftp site. Let me know if you are having trouble finding it. I won't be back to check email until Sunday, though.
Jim
92GTA
I am having trouble then because the only one I can find there was a little 7KB ecu file that only has like 4 variables in it.
Are you saying there is a real full one on there? If so, please point me to it!
leroy
That's probably it. I just threw a few things together to take to the track for tuning. If you can wait a couple of weeks, I'll have a larger one available. There are some size constraints for ecu files, but that may be with Winbin. Remind me in a week or so.
Later,
Jim
BillC
If you are editing 749 bins, another option is Promgrammer. It's $10 shareware, and available on Jas' Granger's web site: http://www.sytyauthority.net/prom.html . It works a little differently than GM ECM Edit, but it lets you edit every 749 parameter & table and adds a few features not available in any other editing program.
Because Promgrammer is a Java-based program, you'll also have to download and install the JRE (Java Runtime Environment), which is free from Sun. Links to the various JRE installers are on the same page on Jas' site, just follow the instructions.
kwick6
FWIW, download the JRE first before downloading promgrammer or it won't work.
If you download promgrammer, then try to download JRE, and go to use promgrammer it won't work. You will have to erase both from your computer and start agian.
Thought I'd throw that out there, as I made the mistake, and I'm no computer expert, so I couldn't figure out why it wouldn't run.
$10 is money well spent here, IMO.
92GTA
Sorry but I don't have any idea what you are talking about? I don't understand what a JRE is and I thought programmers were hardware, not software? And what's this $10 you are talking about?
I use GM ECM Edit to edit the bins using a .ecu file. Then I use the Moates adapter and PP2. I use the 29C256 EEPROM in my MEM-CAL.
Promgrammar takes the place of GM ECM edit.
kwick6
Its callled PROMGRAMMER, and its another option to use for editing bins.
It works awesome.
JRE is a java program used to open the jar file. So in order to use PROMGRAMMER(software), you have to have downloaded the JRE FIRST in order to be able to extract the promgrammer software.
JRE can be downloaded from a link provided on this page...
scroll down you'll see it.
HTH
92GTA
I gotcha now, I always think of a progrmamer and the hardware to upload the bin to the EEPROM, not the bin editor. My bad.
Thanks!
BillC
Thanks!
The program's name is Promgrammer. Please note the "m" after the "o". Maybe it's not the most imaginative name, but I haven't been able to come up with anything better (btw, suggestions are welcome).
92GTA
I see now, stupid me I didn't even notice it was promgrammer and not programmer. I must have been :drinking:
