8.5" or 7 5/8" Eaton diff
Elder Dragon
My stock differential is burned up, plus I need to replace at least one axle.
Currently, I am planning to get a Strange Engineering circle track c-clip eliminator kit with 30 spline axles in combination with an Eaton posi.
My main motivation is I want the truck to be as bulletproof as possible under constant abuse.
My question is: is it worth it to go with an 8.5" setup vs. a 7 5/8"? My preference would be an 8.5", but I am not clear on what I need to make the swap. Do I need a new diff case or will the 8.5" internals fit in the current case? If I need a new case, how do the axle tubes attach to the case? Am I correct in thinking I would need to remove the u-bolts for the springs to allow the diff case swap?
On the Eaton diff: how does the straight line traction and cornering performance compare to the stock diff (when it functions)?
Thanks very much for any info. Sorry if this has already been covered elsewhere on the board, however I haven't found any real clear answers to my questions and I have searched here for quite a while.
Do some searching on the board and you will find the years and models of newer s10's that have 8.5" rear, that will bolt into your truck.
sy#0024 started the thread I am thinking about.
jwaller
Evil Genius/SyTy Guru
the 8.5 is not that big of a differance between the stocker. if you want a good rear, upgrade to the 12 bolt.
ericguy320
Stupid Member
The 8.5 came in the ZR2 and 5 speed 4x4 trucks and blazers if its 98 and above it will haver rear disc brakes. the g80 locking diffs that are in our trucks and almost every GM truck made from the 80's till now are made by eaton and have changed a little through the years mainly to keep them from blowing up like they did when they first came out.
