85 amp alternator
Chasing and finding some electrical gremlins I also discovered that my alt had decided to cease to function. Always interesting when the source of your electricity goes away in the middle of diagnosing other elec issues.:tdown:
Anyway, the reason for the post is that my "original" alt probably wasn't original. It was rated at only 85 amp. I was under the impression that our trucks came with 100/105 amp alt's. Changed before I bought the truck? Might want to take a look at yours.
RealFastV6
@jb_and_his_coffee
Ouch. The stock syty electrical system seems to get quickly overwhelmed with things like dual fuel pumps, e-fans, a relocated battery, maybe different pulleys, etc.
With only an 85A alternator, I can imagine you'd definitely have some issues, especially at night with the headlights on, fog lights, etc. The stock alternator should be 105 amps IIRC. Unfortunately the CS130 comes in a ton of different amperages so incorrect ones will interchange.
Good find Don.
Re: 85 amp alternator
By having the correct voltage in the system I'm gonna virtually going have to start over with tuning the thing, At least I have some notes. Odd, it does already seem to run better...:rotf:
Syclone22
Don i upgraded my alternator with a Mechman unit
and adjustable voltage module so i can adjust my
voltage up to 15 volts for additional accessories
works great and no more dimmer headlights ..
