I am going to try again a little more prepared this time. I still has some unanswered questions though. I have a 88 s15 that had a 2.5 with t5 5 speed in it. The parts I currently have are: Pretty much a whole syclone heart:
motor (120k)
manifolds and crossover
turbo (26k with under 15 thousandths up and down and no in and out shaft play
2 harnesses
2 ecm's
stock gauge cluster
and all the misc stuff needed(intake, fuel rails, injectors, ect)
On the turbo I will use stock return lines if i keep the stock pan. Where is the stock feed line on the block? Can I block off the stock water lines? Instead of the air to water I am running a FMIC with same side inlet/outlet. On the ecm's is there any memcal better than another? One is a Delco AYBM 4053 and the ecm is a silver tint. The other memcal I am unsure of (haven't looked) but the ecm is a goldish tint?
For fueling I am running rubber lines firewall back for now and hardlines under the hood. I will have a 15 gallon fuel cell (with 90 ohm sending unit?) External aeromotive a1000 fuel pump with matching a1000 adjustable fpr.
Transmission will be built 700r4. Yes it will be 2wd. I will have a built 7.5 for now with 3.08 gears and limited slip differential. This will be until I can upgrade to a built ford 8.8.
As far as the accesories I will be running no a/c or power steering pump... that leaves the crank pulley, water pump, and alternator. What will I do for a belt for this setup?
Can I run a 2wd 4.3 oil pan instead of the syclone? I assume I will need 2wd motor mounts? I don't think I left anything out but as more questions come I will ask. Just like to get some answers and opinions on the setup. Thanks for any and all help.
motor (120k)
2 harnesses
2 ecm's
stock gauge cluster
