http://www.summitracing.com/parts/TAY-74232/ and work great for me.
Yes I can see that. I had the time to wait so I emailed asking when they would be back in stock. Was told they were in stock and something was going on with his web site. Everything else that I wanted was in stock and the site showed out of stock. So if anyone finds something on Hood's site and it shows he is out. You may want to contact him.
Whatever wires you purchase make sure you ohm them out... I've had numerous boxes of taylor wires where one would be way off from the rest... good plugs for the money though but if you want to purchase a set and have them last longer then a years time and not scared of dropping a little bit more money either heat shield them or pickup some magnacores
The stock Delcos I put on my 93 15 years ago still seem to be working just fine. They fit in the stock holders, look 'correct' (if that's a concern to you) and cost <$60.00 IIRC.
I'm not a fan of Taylors at all. I've removed several sets from owners' SyTy's that had been installed for only a few months for arcing, torn boots, high resistance, etc that was causing drivability problems. Definitely not worth what they cost, IMO because I don't need to create problems. I want to solve them. Delcos get it done for me.
