90deg bend on FPR for return HELP HELP
DanenGraham
Big in the rear
Ok, i have tried to have a shop localy make me a new small hard line that is a tight 90deg bend to fit under the FPR but they just called me and said they cant do it because they dont have the right fittings.
I searched and found a bunch of people linking back to the same link but it was dead. It also looks like some of you are using part of the stock line then converting it with somthing to a braided (fuel filter).
I am just needing a fix- if you know how i can do this with anything please let me know. So now i have to go up to the shop get that then drive all over town just like i did on friday and have no luck finding anything to get this thing done.
(this is the last missing piece on my truck HELP)
DanenGraham
Big in the rear
Re: 90deg bend on FPR for return HELP HELP
Well just went out and got a inline fuel filter and fittings, going to reuse the stock line down to the rubber hose then just use the filter to adapt to the braided line. what a PITA and waste of my time.
93ty475
what I did on mine was cut the 90 from the stock line and had it brazed to a hydraulic fitting that attached to the hose I used....let me know if you need pics....If you're using aluminum, then what I'm talking about won't work....I know waller and Mike Lee know what aluminum fittings you could use....
tealty
I just got a sag. to -6 npt fitting from Mike at RPM and cut about 1/4" off the end. Then I took a 90* -6 fitting and bent it to look more like 100* and put on some -6 braided line and called it a day. It was a little tight, but still worked.
later
Jordan
