92 Ty throwing a code 32 using the Ultimate Chip.
Bill Z
I have been running the stock chip for the past 3 months and never got a code 32. Then yesterday, I got my replacement Ultimate from Todd. I installed it, installed my 3 bar MAP. Turned up my fuel pressure to 52 pounds with the vacuum disconnected from the regulator. Re-connected the vacuum to the regulator.
On the first drive, everything was running smooth. Really great in fact. After a warm up I got into traffic where I was forced to go miles at 30 MPH (Slow and steady). I set the selector to T115 and just sat back and did what I could to enjoy the ride.
I had my Datamaster connected and all of a sudden, it through a code 32.
Getting home, I got he book out and re read the code 32 definition about exhaust gas recirculation (EGR) circuit problem.
Under certain conditions, when the EGR valve is normally open, the ECM tests the EGR function by de-energizing the EGR control solenoid, blocking vacuum to the EGR valve diaphragm. Without EGR, the system will sense a lean condition and will increase the fuel integrator rate in response. The ECM monitors the amount of fuel delivery increase. If the increase is below a specified value, the ECM will interpret that the test was failed. The failure indicates that closed the EGR valve when it would normally be open does not make a significant change, indicating a problem in the EGR system.
With all of that said, shouldn’t the 52 pounds of fuel pressure (vacuum off) provide enough fuel pressure?
What else should I do?
Re: 92 Ty throwing a code 32 using the Ultimate Chip.
Run T116 which disables it. Do you have the EGR connected? Is the solenoid plugged in? The vacuum connections to the solenoid and egr valve tight?
