93 gmc typhoon
boostedSW
#1691
93 gmc typhoon black/black 60k miles, beautiful interior, all cladding tabs repaired/reinforced, have 5 grand In Receipts for machine work and engine build done by rouche racing engines out of Maryland. An additional 2+ invested in engine parts, 4 grand Into full trans build. Things came up and have to part ways. it's been sitting in my garage for the past 6 years. Always garage kept. 90% of frame and underside cab is finished in por15
Bottom end was built to handle 30lbs boost, Engine is 60 over, short filled, blue printed , cyrocreted crank bigger cam, h beam rods, srp pistons j&e rings, 4 bolt mains pinned an bolted, decked , eddlebrock cam, 1.5/1.6 roller rockers, arp bolts, etc
Jack staples (god rest his soul) was the man behind the entire engine build. I purchased the cam, roller rockers, heads, upper and lower intake manifolds from him after he spent 20+ hours in porting&polishing and some old school tricks he had up his sleve. He ensured me that these heads would flow better than a mild built set of vortecs.
It needs fuel lines, bigger injectors, possibly bigger turbo, air to air and tuning and you will have yourself a 500+hp ty
I’d prefer to sell whole, but may consider parting
Shoot offerers or questions to 4847641655 Josh
Drive train is currently out of vehicle
Hood is not included
Located in center valley, pa 18034
Title in hand
Thank you for viewing. Josh
boostedSW
#1691
I’ve got plenty of pictures just can’t get them to upload, if you text 4847641655 I’d be more than happy to send them your way. Thanks
