93 ty idle miss *UPDATED*
gmcturbo
my truck likes to miss real bad when i start it up and sometimes die. hooked up to scanner - no codes- its fine when driving (for the most part) idle- tach flutter and rpm's all over the place.... i've replaces plugs cr42ts, conrad cap + rotor, fuel filter, K+N air filter, no vaccum leaks -i think everything looks good. im putting some atr black beauties on it soon. (any suggestions on which wires to get?) could it just be the wires? anyone had this prob?
sy112
No expert here but it seems the wires are the only real main issue you haven't addressed. I am running the MSD and have had pretty good luck with them. The resistance was good straight out of the box, have heard that some of the Taylors have bad resistance even when they are new.
HTH
Flyin Ryan
hated cuz he drives fords
It's your wires, I had the same issue when I changed from my taylors to black booties so I changed each wire back to the taylors til I found which wire it was.
gmcturbo
thanks guys, i'm gonna do MSD wires then idle air then coil... should work... btw i put the hurt down on a modded gt mustang 5 speed last night...
gmcturbo
well put some new plugs in and it still has tach flutter and obviously missing, (shaves the truck).its mostly at idle when driving everything seems ok...any suggestions? IAC?
gmcturbo
was it shaking the truck when missing? it also sounds like my #1 cylinder injector is louder than the others... i can toutch it and feel it making the noise pretty good. ill put in a coil today after work... thanks it also revs up and down by itself when i start it sometimes and sometimes the rpm's go really low when i sart it and it dies. any suggestions????
InvisiBill
Use starter fluid while it's running (leaks will suck it in and raise RPMs) or the bicycle tube trick. It's very possible that you have a leak that you didn't see.
gmcturbo
okay i replaced the coil today... still missing but not as bad ( i think) ill look into vaccum lines.... anyone know what is the effect on the engine when a fuel injector(s) is bad?? it still surges when i start it.. also there is a barbed hose connector off the bottom of the intake... looks like a heater core hose could slip over it. it goes directly to the intake... should it have something connected to it?
bjzq8
Intake Manifold Heat...
Those hose barbs are just for the nonexistent coolant passage through the throttle body. In some applications they are used to preclude throttle blade icing...but aren't used in our throttle bodies. Some Quad 4 Beretta guys (I was once heavily involved in Berettas) used to block these off and convince themselves they were gaining some measurable horsepower.
Bill Jenkins
1992 Typhoon #1752
gmcturbo
i hooked the ty to the scanner at work... it said i was only getting 6-7 inches of vaccume at the map sensor. i hooked up a gauge to the map sensor vaccume line and it read 18 inches... i think i found m problem, thanks for all the suggestions!
gmcturbo
gmcturbo
STILL MISSING... replaced MAP sensor... its where it should be on the scanner now... IAC desired and actual are the same. O2 sensor hopping from lean to rich like it should. like i said before my #1 fuel injector ticks VERY loudly...if i feel my exhaust coming from the exhaust pipe, it is spuddering. alternator and battery are OK. checked for vaccume leaks... NON-existant!!
List of replaced stuff so far...
plugs cr42ts
wires
coil
map sensor
air filter
fuel filter
oil change
cap/rotor conrad
PLEASE i really need some help on this one it's depressing me and making me want to sell this beast (just bought it).
