95 / 104 Octane Fuel
RARE_TY
I always read about everyone running 95 or 104 octane fuel. And the ultimate chip (which I am about to order with the 3Bar map sensor) has a setting if I have read it correctly that you can set it to for 95 or 104 octane Fuel. Well my question is where in the world do I go to buy 95/104 octane gas. I live in right out side of Houston and of course all the gas stations have is 93. Do speed shops sell this by the barrel or do you guys go to the airport to get jet fuel??? What gives??
Thanks for the help!!
atc82
why not use xylene? 5 gallons of xylene + 10 gallons of 93 = 100 octane.
You can get xylene at HomeDepot, Lowes, etc... HTH
Sy769
You need to educate yourself about the Ultimate. There is no 95 or otherwise octane settings. If you do not have access to a laptop with Datamaster or someother kind of datalogging software you REALLY do not need a Ultimate yet.
Just trying to save you some frustration- and BG :wink:
RARE_TY
I've never heard of xylene. I am assuming it is some type of Fuel or Fuel addative? I will pump it into GOOGLE and see what I find to learn about it. 8)
Thanks
InvisiBill
atc82 said:
And by that he means http://www.ttspowersystems.com/software.htm...
Xylene is a type of paint thinner. It's a major component used in the little bottles of octane booster you can buy at the gas station. It's 117 octane, so mixed 1:2 with 93 octane premium, you end up with 100 octane. The recipe should be posted here, including fuel system "lubricants" and "cleaners" too.
As was stated, the Ultimate does not have specific octane settings. It does have some settings made for "higher octane than pump" gas. In the end, the requirement comes down to whatever your truck needs at that level so as not to knock, not just a standard ___octane.
2:1 93Gas:117Xylene = 101 octane
3:1 93Gas:117Xylene = 99 octane
The higher mix never did anything for me, but make it harder to start the next morning. I liked filling up the tank completely before I went out to the track anyhow. For a few months my truck never saw anything but 99. You can get your 5 Gallons of Xylene at most paint stores for under $30. Fill the tank with 93 at $1.80 gallon and you have a full tank of Unleaded 99 octane for $2.85/gal
Flyin Ryan
hated cuz he drives fords
This stuffs sounds awsome.. I heard of alot of people using this stuff but what about your 02s.. does it damage them any?
heavy breather
FBI enforcer
I have never had any 02 problems, but make sure to add Marvel Mystery oil to the mix. Xylene is a solvent, and prolonged use without additional lubricant could strip the inside of your injectors.
I've never seen any evidence of Xylene tearing up injectors. If you only run it every couple of tanks, and only run the 99 mix (3:1), than I say you don't need it. After 40 tanks of this, I never had a problem with the fuel system.
It probably helps clean the O2, if it does anything at all. Making your own mix is cheaper ($2.85/gal) than 100 at the pump ($4.00), and doesn't require you to run down your current tank of gas. Most achieve the same track results with this as adding 110 leaded to some of your old 93, but don't lose $50 O2 sensors in the process.
AlaskaTy
What if the state your in only has 91 octane? would a 3:1 ratio come out to around 99 octane? I've heard we only have 91 octane because we're at 5000ft...bozeman, Montana. We could just have crappy gas though.
Jason
It's simple math 15gallonsX91octane=1365
5galofXylene*117octane=585
1365+585=1950/20 = 97.5 Octane
A 2:1 = 99.666 which will probably be better for you. It's not really hard to start, just a few more revs than normal on a cold morning. It's recommended on a 2:1Mix that you use about 3 ounces of MysteryOil or a cap full of Tranny fluid to the batch.
You can use simple average math on blending unleaded, but mixing leaded and unleaded is a little different. The leaded octane number tends to help round up the mixed number.
atc82
(117*5) + (91*15) / 20 = 97.5 octane
this is what you would have if you mixed 3 parts 91 octane to 1 part Xylene (117). HTH
heavy breather
FBI enforcer
There is a formula on the TB.com website that tells exactly how much marvel to add, but I don't remember what it was. In general I just read the label on the bottle and multiply by 1.5
As far as the final octane you just multiply the octane of the gas by the # of gallons you put in, and then multiply the # of gallons of Xylene you use by 117. Add those two number together and divide by the total number of gallons.
Example:
10 gallons of 91 octane and 5 gallons of Xylene
(10x91) + (117x5) divided by 15= total octane
910 + 585=1495 1495/15=99.6666666666 or 100 to make it easier.
justin949
gas
gas
in southern calfornia we have only 91 octane for 2.20 a gallon that is the highest i have seen it it was 1.85 one month ago; i put 89 octane in my typhoon it is all stock and i cant tell the difference from 93 or 89 but when i get some mods they sell 100 octane at the 76 station for 5.00 a gallon (im only putting it in for the strip)
AlaskaTy
Thanks guys -
I didn't know making high octane gas was that easy. I use to throw the 104+ (black bottle) in, but I was only doing that for ease of mind...I'd heard it was garbage. I just found out about a s/c TA in town. He's pushing 8lbs...sure would like to catch him at a light though!
Jason
