98up s-series 4 Wheel Disc brakes
Sy777
I have a set of calipers and discs for 98 up s-series trucks. This setup uses dual piston calipers as opposed to the stock single piston and the discs are larger diam. as well.
I also have the rear discs that came off a blazer. It comes with the mounting brackets, calipers and discs. Both of these come with a brand new set of hawk brake pads.
$265.00 tkes the whole setup.
I'll bring it to nats with me to save shipping if anyone is seriously interested.
2kwik4u
Resident slow guy
Re: 98up s-series 4 Wheel Disc brakes
These are a SIGNIFICANT upgrade from the POS stockers. I made this swap on my '00 2wd S10, and the difference is night and day. I also had this same setup on my old '04 4wd S10 I had for awhile. WAY WAY nicer than the stock Sy/Ty setup.
$265 is a steal too BTW, I paid almost that much for just the fronts from a local junkyard!
Sy777
Not sure, but I would buy new discs and just ship the calipers an brackets. Nothing wrong with these but it might cut down on the shipping. I paid more than 265 for just the rears. I'm just tired of looking at these and I went with a baer set up. The 98up calipers are substantialy larger than the stock syty stuff.
Sy777
It bolts up to a typhoon rear. When I was going to use this rear setup, it did not look like the parking brake pads would clear the rear abs sensors. If you are loosing them then it is not an issue. I did not get a parking break cable figured out but I was going to change to one of a 2dr 98up blazer. The only differece are the ends. Some one on the board that boltsed this setup on told me that it will bolt on will the rear sensors. Just looked a little tight to me.
