A/C clutch question
vinnieTy
TY # 1889
The clutch on my A/C compressor is bad and slipping. My truck still has R12 and works great except for this issue. Is there a way to replace just the clutch on the compressor or is this more difficult then i'm hoping it will be.
I this is a part that sells separate a part number would be appreciated.
Thanks..:tup:
vinnieTy
TY # 1889
Re: A/C clutch question
Does it slip right as soon as it engages, or does it have to operate for awhile? If it takes a while, the slipping may be an indication of high head pressure caused by inadequate air flow through the condenser.
Do you have electric cooling fans? Are they running? If you still have the stock engine driven fan, is the clutch engaged? Rev it up to about 2,000 RPM and shut off the key. Watch the fan, if it freewheels, you have a bad fan clutch.
You might also check the voltage at the clutch. My Blazer had this problem for about a week, and I didn't get right on figuring it out, but then the alternator finally augured-in. Turns out the alternator was dying, and low system voltage was causing the slipping. New alternator fixed it.
There's some ideas.
Hey Dave. There is thick black dirt / dust all over the front of the compressor. It will go on and off unless i have it on MAX which it use to stay on constant at least from the amount of times looking at it with hood open. Now it will engage on and off and smoke will come out of it like the clutch is slipping. When it does engage the a/c is cold. Maybe not that cold but cold.
As for the other questions the answers are:
-no electric fans
-ungraded water pump
-160 t-stat
-astro van six blade fan
-new rad hoses
Those items were done a few years ago.
I assume the clutch on my AC compressor is worn out as well. It makes a bad knocking sound when the AC is on.
randy merritt
Mine was doing this recently. It turned out to be a stretched belt that was vibrating and making a god awful noise. It sounded just like a metallic knock. Replaced belt, no more noise.
vinnieTy
TY # 1889
Has anyone replaced a compressor clutch that can share the part number and on how hard it was to get done?
Thanks
