A/C Controls
tbauer03
TRBOBOX
My A/C will turn on with the switch and the off position turns it off but in every other position it will only blow out the very bottom and very top it will never blow through the vents and it really sucks bc it is really hot right now in KS and my drivers side window is broke. My guess is there is something efffed up with the switch but could it be anything else?
leroy
There's a vacuum line back by the distributor/egr/ fuel pressure regulator area that goes to the HVAC. Make sure it's connected. Otherwise I would suspect a vacuum leak between that connection and the hvac controls.
Jim
bdubb
I am teh kingpin!
Jim
yeah what Jim said, its a hard black line, if it helps.
tbauer03
TRBOBOX
Thanks Jim!
Took me 2 secs and now i can enjoy nice AC 8)
Have i ever told you that you are genius with the these trucks?
I have your # listed on my cell phone has "Jim The SyTy God"
How much do i owe you this time?
leroy
Don't give me too much credit. I probably knocked it loose when we put that fuel pressure regulator on. :lol:
Jim
tbauer03
TRBOBOX
Leroy: Don't give me too much credit. I probably knocked it loose when we put that fuel pressure regulator on.
Nah I gaurentee that i did it when i was messing around with the IC lines.
