A/C delete
92TyLA
Re: A/C delete
is this the RPM kit?
of so dibs, if not dibs pending some info
you have the belt?
Syclone#2960
What ever it takes!!
Re: A/C delete
you have the belt?
I dont think I have the belt...I was running a smaller UD pulley so it did me no good. Are running the stock pulley? This is the RPM unit.
92TyLA
Re: A/C delete
$$ sent, can you ship to
8635 Long Beach blvd
South Gate CA 90280
thanks again
Re: A/C delete
I have that kit, works fine except... The belt, at least in my case was to long causing the tensioner to go over-center. There is no slightly shorter belt that I could find. I made a simple adapter (not purdy but functional) to move the tensioner closer to the water pump so it would accept the next shorter belt that I could find. All other pulleys are stock BTW. All other bolts are in their normal location.
I will try to get the belt # tomorrow, otherwise I'm on vacation.
I've been using it this way for a while now with no issues.
Just something to watch out for.
HTH
1BADV6
Re: A/C delete
My RPM setup came with a Dayco 5060825 which cross references over to a 825K6. It is 83.25" long. The 850K6 is 87.75" long.
