You take the nut off in the center of the clutch
Then you use a clutch plate remover to get the clutch plate off. It threads in to the threads in the center of the clutch plate and has a bolt that pushes against the shaft. You then have access to the pulley to get it off.
I guess i need to remove the compressor so i can get a better view because i don't see a nut in there. If there is a nut what is the size?
